GatewayESP32.ino
21  * REVISION HISTORY
22  * Version 1.0 - tekka
23  *
24  * DESCRIPTION
25  * The ESP32 gateway sends data received from sensors to the WiFi link.
26  * The gateway also accepts input on ethernet interface, which is then sent out to the radio network.
27  *
28  * Make sure to fill in your ssid and WiFi password below.
29  */
31 // Enable debug prints to serial monitor
32 #define MY_DEBUG
34 // Enables and select radio type (if attached)
35 #define MY_RADIO_RF24
36 //#define MY_RADIO_RFM69
37 //#define MY_RADIO_RFM95
39 #define MY_GATEWAY_ESP32
41 #define MY_WIFI_SSID "MySSID"
42 #define MY_WIFI_PASSWORD "MyVerySecretPassword"
44 // Enable UDP communication
45 //#define MY_USE_UDP // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
47 // Set the hostname for the WiFi Client. This is the hostname
48 // passed to the DHCP server if not static.
49 #define MY_HOSTNAME "ESP32_GW"
51 // Enable MY_IP_ADDRESS here if you want a static ip address (no DHCP)
52 //#define MY_IP_ADDRESS 192,168,1,100
54 // If using static ip you can define Gateway and Subnet address as well
55 //#define MY_IP_GATEWAY_ADDRESS 192,168,1,1
56 //#define MY_IP_SUBNET_ADDRESS 255,255,255,0
58 // The port to keep open on node server mode
59 #define MY_PORT 5003
61 // How many clients should be able to connect to this gateway (default 1)
62 #define MY_GATEWAY_MAX_CLIENTS 2
64 // Controller ip address. Enables client mode (default is "server" mode).
65 // Also enable this if MY_USE_UDP is used and you want sensor data sent somewhere.
66 //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68
67 //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
69 #include <MySensors.h>
71 void setup()
72 {
73  // Setup locally attached sensors
74 }
77 {
78  // Present locally attached sensors here
79 }
81 void loop()
82 {
83  // Send locally attached sensors data here
84 }
Definition: GatewayESP32.ino:81
Definition: GatewayESP32.ino:76
Definition: GatewayESP32.ino:71
