UVSensor.ino
21  * REVISION HISTORY
22  * Version 1.0 - epierre
23  * Contribution: bulldoglowell, gizmocuz
24  *
25  * DESCRIPTION
26  * Arduino UVM-30A
27  * Index table taken from: http://www.elecrow.com/sensors-c-111/environment-c-111_112/uv-sensor-moduleuvm30a-p-716.html
28  * Because this table is pretty lineair, we can calculate a UVI with one decimal
29  *
30  * Connect sensor:
31  *
32  * + >>> 5V
33  * - >>> GND
34  * out >>> A0
35  *
36  * License: Attribution-NonCommercial-ShareAlike 3.0 Unported (CC BY-NC-SA 3.0)
37  */
39 // Enable debug prints to serial monitor
40 #define MY_DEBUG
42 // Enable and select radio type attached
43 #define MY_RADIO_RF24
44 //#define MY_RADIO_NRF5_ESB
45 //#define MY_RADIO_RFM69
46 //#define MY_RADIO_RFM95
47 //#define MY_PJON
49 #include <MySensors.h>
51 #define UV_SENSOR_ANALOG_PIN 0
53 #define CHILD_ID_UV 0
55 uint32_t SLEEP_TIME = 30*1000; // Sleep time between reads (in milliseconds)
57 MyMessage uvMsg(CHILD_ID_UV, V_UV);
59 uint32_t lastSend =0;
60 float uvIndex;
61 float lastUV = -1;
62 uint16_t uvIndexValue [12] = { 50, 227, 318, 408, 503, 606, 696, 795, 881, 976, 1079, 1170};
66 {
67  // Send the sketch version information to the gateway and Controller
68  sendSketchInfo("UV Sensor", "1.2");
70  // Register all sensors to gateway (they will be created as child devices)
71  present(CHILD_ID_UV, S_UV);
72 }
74 void loop()
75 {
76  uint32_t currentTime = millis();
78  uint16_t uv = analogRead(UV_SENSOR_ANALOG_PIN);// Get UV value
79  if (uv>1170) {
80  uv=1170;
81  }
83  //Serial.print("UV Analog reading: ");
84  //Serial.println(uv);
86  int i;
87  for (i = 0; i < 12; i++) {
88  if (uv <= uvIndexValue[i]) {
89  uvIndex = i;
90  break;
91  }
92  }
94  if(i==12) {
95  i--;
96  }
98  //calculate 1 decimal if possible
99  if (i>0) {
100  float vRange=uvIndexValue[i]-uvIndexValue[i-1];
101  float vCalc=uv-uvIndexValue[i-1];
102  uvIndex+=(1.0/vRange)*vCalc-1.0;
103  }
105  //Serial.print("UVI: ");
106  //Serial.println(uvIndex,2);
108  //Send value to gateway if changed, or at least every 5 minutes
109  if ((uvIndex != lastUV)||(currentTime-lastSend >= 5UL*60UL*1000UL)) {
110  lastSend=currentTime;
111  send(uvMsg.set(uvIndex,2));
112  lastUV = uvIndex;
113  }
115  sleep(SLEEP_TIME);
116 }
Definition: UVSensor.ino:74
Definition: UVSensor.ino:65
MyMessage::set
send
present
sleep
Definition: MyMessage.h:303
