+ Collaboration diagram for Signing related debug messages:
Explanation of the abstract signing related debug messages.
MySigning-related log messages, format: [!]SYSTEM:SUB SYSTEM:MESSAGE
MySigning debug log messages:
E SYS SUB Message Comment
SGN INI BND OK Backend has initialized ok
! SGN INI BND FAIL Backend has not initialized ok
SGN PER OK Personalization data is ok
! SGN PER TAMPERED Personalization data has been tampered
SGN PRE SGN REQ Signing required
SGN PRE SGN REQ,TO='node' Tell 'node' that we require signing
SGN PRE SGN REQ,FROM='node' Node 'node' require signing
SGN PRE SGN NREQ Signing not required
SGN PRE SGN REQ,TO='node' Tell 'node' that we do not require signing
SGN PRE SGN NREQ,FROM='node' Node 'node' does not require signing
! SGN PRE SGN NREQ,FROM='node' REJ Node 'node' does not require signing but used to (requirement remain unchanged)
SGN PRE WHI REQ Whitelisting required
SGN PRE WHI REQ,TO='node' Tell 'node' that we require whitelisting
SGN PRE WHI REQ,FROM='node' Node 'node' require whitelisting
SGN PRE WHI NREQ Whitelisting not required
SGN PRE WHI NREQ,TO='node' Tell 'node' that we do not require whitelisting
SGN PRE WHI NREQ,FROM='node' Node 'node' does not require whitelisting
! SGN PRE WHI NREQ,FROM='node' REJ Node 'node' does not require whitelisting but used to (requirement remain unchanged)
SGN PRE XMT,TO='node' Presentation data transmitted to 'node'
! SGN PRE XMT,TO='node' FAIL Presentation data not properly transmitted to 'node'
SGN PRE WAIT GW Waiting for gateway presentation data
! SGN PRE VER='version' Presentation version 'version' is not supported
SGN PRE NSUP Received signing presentation but signing is not supported
SGN PRE NSUP,TO='node' Informing 'node' that we do not support signing
SGN SGN NCE REQ,TO='node' Nonce request transmitted to 'node'
! SGN SGN NCE REQ,TO='node' FAIL Nonce request not properly transmitted to 'node'
! SGN SGN NCE TMO Timeout waiting for nonce
SGN SGN SGN Message signed
! SGN SGN SGN FAIL Message failed to be signed
SGN SGN NREQ='node' 'node' does not require signed messages
SGN SGN 'sender'!='us' NUS Will not sign because 'sender' is not 'us' (repeater)
! SGN SGN STATE Security system in a invalid state (personalization data tampered)
! SGN VER NSG Message was not signed, but it should have been
! SGN VER FAIL Verification failed
SGN VER OK Verification succeeded
SGN VER LEFT='number' 'number' of failed verifications left in a row before node is locked
! SGN VER STATE Security system in a invalid state (personalization data tampered)
SGN SKP MSG CMD='cmd',TYPE='type' Message with command 'cmd' and type 'type' does not need to be signed
SGN SKP ECHO CMD='cmd',TYPE='type' ECHO messages does not need to be signed
SGN NCE LEFT='number' 'number' of nonce requests between successful verifications left before node is locked
SGN NCE XMT,TO='node' Nonce data transmitted to 'node'
! SGN NCE XMT,TO='node' FAIL Nonce data not properly transmitted to 'node'
! SGN NCE GEN Failed to generate nonce
SGN NCE NSUP (DROPPED) Ignored nonce/request for nonce (signing not supported)
SGN NCE FROM='node' Received nonce from 'node'
SGN NCE 'sender'!='dst' (DROPPED) Ignoring nonce as it did not come from the designation of the message to sign
! SGN BND INIT FAIL Failed to initialize signing backend
! SGN BND PWD<8 Signing password too short
! SGN BND PER Backend not personalized
! SGN BND SER Could not get device unique serial from backend
! SGN BND TMR Backend timed out
! SGN BND SIG,SIZE,'message'>'max' Refusing to sign 'message' because it is bigger than 'max' allowed size
SGN BND SIG WHI,ID='id' Salting message with our 'id'
SGN BND SIG WHI,SERIAL='serial' Salting message with our 'serial'
! SGN BND VER ONGOING Verification failed, no ongoing session
! SGN BND VER,IDENT='identifier' Verification failed, 'identifier' is unknown
SGN BND VER WHI,ID='sender' 'sender' found in whitelist
SGN BND VER WHI,SERIAL='serial' Expecting 'serial' for this sender
! SGN BND VER WHI,ID='id' MISSING 'id' not found in whitelist
SGN BND NONCE='nonce' Calculating signature using 'nonce'
SGN BND HMAC='hmac' Calculated signature is 'hmac'
