LightSensor.ino
21  * REVISION HISTORY
22  * Version 1.0 - Henrik EKblad
23  *
24  * DESCRIPTION
25  * Example sketch showing how to measure light level using a LM393 photo-resistor
26  * http://www.mysensors.org/build/light
27  */
29 // Enable debug prints to serial monitor
30 #define MY_DEBUG
32 // Enable and select radio type attached
33 #define MY_RADIO_RF24
34 //#define MY_RADIO_NRF5_ESB
35 //#define MY_RADIO_RFM69
36 //#define MY_RADIO_RFM95
38 #include <MySensors.h>
40 #define CHILD_ID_LIGHT 0
41 #define LIGHT_SENSOR_ANALOG_PIN 0
43 uint32_t SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
45 MyMessage msg(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
46 int lastLightLevel;
50 {
51  // Send the sketch version information to the gateway and Controller
52  sendSketchInfo("Light Sensor", "1.0");
54  // Register all sensors to gateway (they will be created as child devices)
55  present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
56 }
58 void loop()
59 {
60  int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
61  Serial.println(lightLevel);
62  if (lightLevel != lastLightLevel) {
63  send(msg.set(lightLevel));
64  lastLightLevel = lightLevel;
65  }
66  sleep(SLEEP_TIME);
67 }
Definition: LightSensor.ino:58
Definition: LightSensor.ino:49
MyMessage::set
send
present
sleep
Definition: MyMessage.h:289
