35 #define RF69_MAX_DATA_LEN 61 // to take advantage of the built in AES/CRC we want to limit the frame size to the internal FIFO size (66 bytes - 3 bytes overhead - 2 bytes crc) 36 #define RF69_SPI_CS SS // SS is the SPI slave select pin, for instance D10 on ATmega328 39 #if defined(__AVR_ATmega168__) || defined(__AVR_ATmega328P__) || defined(__AVR_ATmega88) || defined(__AVR_ATmega8__) || defined(__AVR_ATmega88__) 40 #define RF69_IRQ_PIN 2 41 #define RF69_IRQ_NUM 0 42 #elif defined(__AVR_ATmega644P__) || defined(__AVR_ATmega1284P__) 43 #define RF69_IRQ_PIN 2 44 #define RF69_IRQ_NUM 2 45 #elif defined(__AVR_ATmega32U4__) 46 #define RF69_IRQ_PIN 3 47 #define RF69_IRQ_NUM 0 48 #elif defined(__arm__)//Use pin 10 or any pin you want 49 #define RF69_IRQ_PIN 10 50 #define RF69_IRQ_NUM 10 52 #define RF69_IRQ_PIN 2 53 #define RF69_IRQ_NUM 0 57 #define CSMA_LIMIT -90 // upper RX signal sensitivity threshold in dBm for carrier sense access 58 #define RF69_MODE_SLEEP 0 // XTAL OFF 59 #define RF69_MODE_STANDBY 1 // XTAL ON 60 #define RF69_MODE_SYNTH 2 // PLL ON 61 #define RF69_MODE_RX 3 // RX MODE 62 #define RF69_MODE_TX 4 // TX MODE 65 #define RF69_315MHZ 31 // non trivial values to avoid misconfiguration 66 #define RF69_433MHZ 43 67 #define RF69_868MHZ 86 68 #define RF69_915MHZ 91 71 #define COURSE_TEMP_COEF -90 // puts the temperature reading in the ballpark, user can fine tune the returned value 72 #define RF69_BROADCAST_ADDR 255 73 #define RF69_CSMA_LIMIT_MS 1000 74 #define RF69_TX_LIMIT_MS 1000 75 #define RF69_FSTEP 61.03515625 // == FXOSC / 2^19 = 32MHz / 2^19 (p13 in datasheet) 78 #define RFM69_CTL_SENDACK 0x80 79 #define RFM69_CTL_REQACK 0x40 85 static volatile uint8_t
DATA[RF69_MAX_DATA_LEN];
91 static volatile uint8_t
93 static volatile int16_t
RSSI;
104 RFM69(uint8_t slaveSelectPin=RF69_SPI_CS, uint8_t interruptPin=RF69_IRQ_PIN,
bool isRFM69HW=
false,
105 uint8_t interruptNum=RF69_IRQ_NUM)
110 _mode = RF69_MODE_STANDBY;
115 #if defined (SPCR) && defined (SPSR) 121 bool initialize(uint8_t freqBand, uint8_t ID, uint8_t networkID=1);
125 virtual void send(uint8_t toAddress,
const void* buffer, uint8_t bufferSize,
126 bool requestACK=
false);
127 virtual bool sendWithRetry(uint8_t toAddress,
128 uint8_t retries=2, uint8_t retryWaitTime=
133 virtual void sendACK(
const void* buffer =
"", uint8_t bufferSize=0);
137 void setCS(uint8_t newSPISlaveSelect);
138 int16_t
readRSSI(
bool forceTrigger=
false);
149 void writeReg(uint8_t addr, uint8_t val);
156 virtual void sendFrame(uint8_t toAddress,
const void* buffer, uint8_t size,
bool requestACK=
false,
167 #if defined (SPCR) && defined (SPSR) 173 virtual void setMode(uint8_t mode);
uint8_t readReg(uint8_t addr)
readReg
bool ACKRequested()
ACKRequested.
uint8_t _interruptNum
_interruptNum
Definition: RFM69.h:162
static volatile uint8_t SENDERID
SENDERID.
Definition: RFM69.h:87
virtual bool receiveDone()
receiveDone
void readAllRegs()
readAllRegs
virtual void receiveBegin()
receiveBegin
virtual void interruptHandler()
interruptHandler
uint8_t _interruptPin
_interruptPin
Definition: RFM69.h:161
void rcCalibration()
rcCalibration (calibrate the internal RC oscillator for use in wide temperature variations - see data...
static volatile uint8_t PAYLOADLEN
PAYLOADLEN.
Definition: RFM69.h:89
bool ACKReceived(uint8_t fromNodeID)
ACKReceived.
static volatile uint8_t DATALEN
DATALEN.
Definition: RFM69.h:86
virtual void unselect()
unselect
virtual void select()
select
virtual void setHighPowerRegs(bool onOff)
setHighPowerRegs
bool _promiscuousMode
_promiscuousMode
Definition: RFM69.h:164
static volatile uint8_t _mode
should be protected?
Definition: RFM69.h:94
static volatile int16_t RSSI
most accurate RSSI during reception (closest to the reception)
Definition: RFM69.h:93
uint8_t readTemperature(uint8_t calFactor=0)
readTemperature (get CMOS temperature (8bit))
static volatile uint8_t ACK_RECEIVED
Should be polled immediately after sending a packet with ACK requestwith ACK request.
Definition: RFM69.h:92
initialize
static RFM69 * selfPointer
selfPointer
Definition: RFM69.h:159
uint8_t _address
_address
Definition: RFM69.h:163
setCS
void setFrequency(uint32_t freqHz)
setFrequency
RFM69(uint8_t slaveSelectPin=RF69_SPI_CS, uint8_t interruptPin=RF69_IRQ_PIN, bool isRFM69HW=false, uint8_t interruptNum=RF69_IRQ_NUM)
Constructor.
Definition: RFM69.h:104
virtual bool sendWithRetry(uint8_t toAddress, const void *buffer, uint8_t bufferSize, uint8_t retries=2, uint8_t retryWaitTime=40)
sendWithRetry (40ms roundtrip req for 61byte packets)
setMode
bool _isRFM69HW
_isRFM69HW
Definition: RFM69.h:166
static volatile uint8_t ACK_REQUESTED
ACK_REQUESTED.
Definition: RFM69.h:90
void setNetwork(uint8_t networkID)
setNetwork
void promiscuous(bool onOff=true)
promiscuous
static volatile uint8_t DATA[RF69_MAX_DATA_LEN]
recv/xmit buf, including hdr & crc bytes
Definition: RFM69.h:85
virtual void setHighPower(bool onOFF=true)
setHighPower (have to call it after initialize for RFM69HW)
virtual void sendFrame(uint8_t toAddress, const void *buffer, uint8_t size, bool requestACK=false, bool sendACK=false)
sendFrame
int16_t readRSSI(bool forceTrigger=false)
readRSSI
virtual void sendACK(const void *buffer="", uint8_t bufferSize=0)
sendACK
virtual void setPowerLevel(uint8_t level)
setPowerLevel (reduce/increase transmit power level)
virtual void send(uint8_t toAddress, const void *buffer, uint8_t bufferSize, bool requestACK=false)
send
virtual void interruptHook(uint8_t CTLbyte)
interruptHook
writeReg
uint8_t _powerLevel
_powerLevel
Definition: RFM69.h:165
uint32_t getFrequency()
getFrequency
uint8_t _slaveSelectPin
_slaveSelectPin
Definition: RFM69.h:160
void setAddress(uint8_t addr)
setAddress
void encrypt(const char *key)
encrypt
static volatile uint8_t TARGETID
should match _address
Definition: RFM69.h:88
