Classes | Macros | Typedefs | Enumerations
CC1101.h File Reference
#include "CC1101Registers.h"
#include <stdint.h>
+ Include dependency graph for CC1101.h:
Classes
union  cc1101_controlFlags_t
 Control flag data type. More...
struct  __attribute__
 FW config structure, stored in eeprom. More...
struct  cc1101_internal_t
 CC1101 internal variables. More...
#define CC1101_SPI   hwSPI
 default SPI
#define DEFAULT_CC1101_GD0_PIN   (2)
 DEFAULT_CC1101_GD0_PIN.
#define DEFAULT_CC1101_CS_PIN   (SS)
 DEFAULT_CC1101_CS_PIN.
#define CC1101_CRYSTAL_HZ   26000000LL
#define CC1101_315MHZ   315000000LL
#define CC1101_433MHZ   433100000LL
#define CC1101_868MHZ   868100000LL
#define CC1101_915MHZ   915100000LL
#define CC1101_FREQ_VAL   (((MY_CC1101_FREQUENCY)*65536LL) / CC1101_CRYSTAL_HZ)
#define CC1101_FREQ_BYTE0   ((CC1101_FREQ_VAL >> 16) & 0xFF)
#define CC1101_FREQ_BYTE1   ((CC1101_FREQ_VAL >> 8) & 0xFF)
#define CC1101_FREQ_BYTE2   (CC1101_FREQ_VAL & 0xFF)
#define MY_CC1101_POWER_LEVEL   CC1101_POWER_AUTO
 Sets the transmit power level. More...
#define MY_CC1101_MIN_POWER_LEVEL   (0)
 Sets the minimum allowable output power level for AUTO. Default: -30dBm (0.001mW)
#define MY_CC1101_MAX_POWER_LEVEL   (7)
 Sets the maximum allowable output power level for AUTO. Default: 10dBm (10mW) More...
#define CC1101_ATC_TARGET_RANGE_DBM   (15)
 ATC target range +/- dBm.
#define CC1101_RSSI_OFFSET   (74u)
 RSSI offset.
#define CC1101_TARGET_RSSI   (-50)
 RSSI target.
#define CC1101_MODEM_S_BR4_8_FD20   0
 135KHz bandwidth, 4800 baud, 19kHz deviation
#define CC1101_MODEM_M_BR38_4_FD20   1
 200KHz bandwidth, 38400 baud, 47kHz deviation
#define CC1101_MODEM_F_BR100_FD50   2
 200KHz bandwidth, 100000 baud, 47kHz deviation
#define CC1101_MODEM_XF_BR250_FD125   3
 320KHz bandwidth, 250000 baud, 125kHz deviation
#define MY_CC1101_MODEM_CONFIGURATION   CC1101_MODEM_M_BR38_4_FD20
 Defines the model speed and modulation parameters. More...
#define CC1101_MAX_PACKET_LEN   (0x40u)
 Maximum packet size that can be carried by the modem.
#define CC1101_PREAMBLE_LENGTH   (8u)
 Preamble length, default=8.
#define CC1101_BROADCAST_ADDRESS   0xFF
#define MY_CC1101_SYNC_WORD   0xF543
 Sync word, can be used to separate networks. More...
#define CC1101_TX_RETRIES   (5u)
 Retries in case of fail to transmit (eg CCA)
#define MY_CC1101_TX_TIMEOUT_MS   (50ul)
 Timeout before TX is considered failed.
#define MY_CC1101_TX_RETRY_DELAY_MS   (50l)
 Delay before reattempting transmit.
#define CC1101_SEND_RETRIES   (4u)
 Retries in case ACK is not received.
#define MY_CC1101_SEND_TIMEOUT_MS   (500ul)
 How long to wait for an ACK.
#define MY_CC1101_ACK_SEND_DELAY_MS   5
#define MY_CC1101_CSN_TIMEOUT_MS   (2ul)
 CSN to SO low timeout.
#define CC1101_RETRY_TIMEOUT_MS   (1000ul)
#define CC1101_WRITE_SINGLE   0x00
#define CC1101_WRITE_BURST   0x40
#define CC1101_READ_SINGLE   0x80
#define CC1101_READ_BURST   0xC0
#define CC1101_HEADER_LEN   sizeof(cc1101_header_t)
 Size header inside payload.
#define CC1101_MAX_PAYLOAD_LEN   (CC1101_MAX_PACKET_LEN - CC1101_HEADER_LEN)
 Max payload length.
#define CC1101_PACKET_HEADER_VERSION   (1u)
 CC1101 packet header version.
#define CC1101_MIN_PACKET_HEADER_VERSION   (1u)
 Minimal CC1101 packet header version.
Typedefs
typedef enum cc1101PowerLevel_e cc1101_powerLevel_t
typedef uint16_t cc1101_sequenceNumber_t
 Sequence number data type.
typedef int8_t cc1101_RSSI_t
 RSSI data type.
typedef uint8_t cc1101_LQI_t
 LQI data type.
typedef uint8_t cc1101_status_t
 Chip status byte.
Enumerations
enum  cc1101PowerLevel_e {
  CC1101_POWER_0 = 0x0, CC1101_POWER_1 = 0x1, CC1101_POWER_2 = 0x2, CC1101_POWER_3 = 0x3,
  CC1101_POWER_4 = 0x4, CC1101_POWER_5 = 0x5, CC1101_POWER_6 = 0x6, CC1101_POWER_7 = 0x7,
  CC1101_POWER_AUTO = 0xff
enum  cc1101_radioModes_t {
  CC1101_MODE_SLEEP = 0x00, CC1101_MODE_IDLE, CC1101_MODE_FS, CC1101_MODE_TX,
  CC1101_MODE_RX, CC1101_MODE_CCA
 CC1101 operation Modes. More...
