+ Collaboration diagram for CC1101:
These options are specific to the CC1101 family of wireless transport modules.
#define MY_RADIO_CC1101
 Define this to use CC1101 based radios for sensor network communication.
#define MY_CC1101_CS_PIN   DEFAULT_CC1101_CS_PIN
 CC1101 SPI chip select pin.
#define MY_CC1101_GD0_PIN   DEFAULT_CC1101_GD0_PIN
 cc1101 GD0 pin
#define MY_CC1101_GD0_NUM   digitalPinToInterrupt(MY_CC1101_GD0_PIN)
#define MY_CC1101_FREQUENCY   (CC1101_433MHZ)
 The base frequency to use. More...
#define MY_CC1101_CHANNEL   4
 The channel number to use. More...
#define MY_CC1101_SYNC_WORD   0xF543
 Sync word, can be used to separate networks. More...
#define MY_CC1101_MODEM_CONFIGURATION   CC1101_MODEM_M_BR38_4_FD20
 Defines the model speed and modulation parameters. More...
#define MY_CC1101_POWER_LEVEL   CC1101_POWER_AUTO
 Sets the transmit power level. More...
#define MY_CC1101_ATC_TARGET_DBM   (-50)
 Sets the target RSSI level for the ATC. Defaults to -50dBm.
#define MY_CC1101_MAX_POWER_LEVEL   (7)
 Sets the maximum allowable output power level for AUTO. Default: 10dBm (10mW) More...
◆ MY_CC1101_CHANNEL
The actual carrier frequency is given by the base frequency, plus the channel bandwidth x channel number.
The defaults of this driver set a base frequency of 433.1MHz, a bandwidth of 200KHz and channel 4, giving a carrier frequency of 433.9MHz.
Definition at line 1373 of file MyConfig.h.
◆ MY_CC1101_FREQUENCY
  • CC1101_315MHZ
  • CC1101_433MHZ
  • CC1101_868MHZ
  • CC1101_915MHZ
This must match the hardware version of the CC1101 radio. Additional information: https://en.wikipedia.org/wiki/Short_Range_Devices
Definition at line 1359 of file MyConfig.h.
◆ MY_CC1101_MAX_POWER_LEVEL
Please check local regulations!
◆ MY_CC1101_MODEM_CONFIGURATION
Available options (all 2FSK modulation):
  • CC1101_MODEM_S_BR4_8_FD20 - 4.8kBaud
  • CC1101_MODEM_M_BR38_4_FD20 - 38.4kBaud [default]
  • CC1101_MODEM_F_BR100_FD50 - 100kBaud
  • CC1101_MODEM_XF_BR250_FD125 - 250kBaud
Slower speeds can provide for longer range, though as they have a longer transmit time, they can consume more power overall.
◆ MY_CC1101_POWER_LEVEL
There are 8 options, CC1101_POWER_[0-7] which range from -30dBm to 10dBm.
For nodes this defaults to CC1101_POWER_AUTO which uses signal reports to automatically adjust the level.
For gateways, this defaults to CC1101_POWER_6. Using AUTO for gateways and repeaters may be a problem if there are multiple nodes that will have different reception quality, so only use AUTO if nodes have similar distance and reception.
◆ MY_CC1101_SYNC_WORD
Sync word can be used to differentiate multiple networks on a channel.
The CC1101 radio transmits this at the start of each packet and on reception discards packets with mismatched sync words. You can change this to create multiple logical networks on the same radio channel, or avoid interference from nearby CC1101 based radios not in your network.
