These functions let you use SPI0 (Serial Peripheral Interface) to interface with an external SPI device.
| int bcm2835_spi_begin |
void |
Start SPI operations. Forces RPi SPI0 pins P1-19 (MOSI), P1-21 (MISO), P1-23 (CLK), P1-24 (CE0) and P1-26 (CE1) to alternate function ALT0, which enables those pins for SPI interface. You should call bcm2835_spi_end() when all SPI funcitons are complete to return the pins to their default functions.
- See also
- bcm2835_spi_end()
- Returns
- 1 if successful, 0 otherwise (perhaps because you are not running as root)
| void bcm2835_spi_chipSelect |
uint8_t |
cs | ) |
Sets the chip select pin(s) When an bcm2835_spi_transfer() is made, the selected pin(s) will be asserted during the transfer.
- Parameters
| [in] | cs | Specifies the CS pins(s) that are used to activate the desired slave. One of BCM2835_SPI_CS*, see bcm2835SPIChipSelect |
| void bcm2835_spi_end |
void |
End SPI operations. SPI0 pins P1-19 (MOSI), P1-21 (MISO), P1-23 (CLK), P1-24 (CE0) and P1-26 (CE1) are returned to their default INPUT behaviour.
| void bcm2835_spi_setBitOrder |
uint8_t |
order | ) |
Sets the SPI bit order NOTE: has no effect. Not supported by SPI0. Defaults to
- Parameters
| void bcm2835_spi_setChipSelectPolarity |
uint8_t |
cs, |
uint8_t |
active |
Sets the chip select pin polarity for a given pin When an bcm2835_spi_transfer() occurs, the currently selected chip select pin(s) will be asserted to the value given by active. When transfers are not happening, the chip select pin(s) return to the complement (inactive) value.
- Parameters
| [in] | cs | The chip select pin to affect |
| [in] | active | Whether the chip select pin is to be active HIGH |
| void bcm2835_spi_setClockDivider |
uint16_t |
divider | ) |
Sets the SPI clock divider and therefore the SPI clock speed.
- Parameters
| void bcm2835_spi_setDataMode |
uint8_t |
mode | ) |
Sets the SPI data mode Sets the clock polariy and phase
- Parameters
| [in] | mode | The desired data mode, one of BCM2835_SPI_MODE*, see bcm2835SPIMode |
| uint8_t bcm2835_spi_transfer |
uint8_t |
value | ) |
Transfers one byte to and from the currently selected SPI slave. Asserts the currently selected CS pins (as previously set by bcm2835_spi_chipSelect) during the transfer. Clocks the 8 bit value out on MOSI, and simultaneously clocks in data from MISO. Returns the read data byte from the slave. Uses polled transfer as per section 10.6.1 of the BCM 2835 ARM Peripherls manual
- Parameters
| [in] | value | The 8 bit data byte to write to MOSI |
- Returns
- The 8 bit byte simultaneously read from MISO
- See also
- bcm2835_spi_transfern()
| void bcm2835_spi_transfern |
char * |
buf, |
uint32_t |
len |
Transfers any number of bytes to and from the currently selected SPI slave using bcm2835_spi_transfernb. The returned data from the slave replaces the transmitted data in the buffer.
- Parameters
| [in,out] | buf | Buffer of bytes to send. Received bytes will replace the contents |
| [in] | len | Number of bytes int eh buffer, and the number of bytes to send/received |
- See also
- bcm2835_spi_transfer()
| void bcm2835_spi_transfernb |
char * |
tbuf, |
char * |
rbuf, |
uint32_t |
len |
Transfers any number of bytes to and from the currently selected SPI slave. Asserts the currently selected CS pins (as previously set by bcm2835_spi_chipSelect) during the transfer. Clocks the len 8 bit bytes out on MOSI, and simultaneously clocks in data from MISO. The data read read from the slave is placed into rbuf. rbuf must be at least len bytes long Uses polled transfer as per section 10.6.1 of the BCM 2835 ARM Peripherls manual
- Parameters
| [in] | tbuf | Buffer of bytes to send. |
| [out] | rbuf | Received bytes will by put in this buffer |
| [in] | len | Number of bytes in the tbuf buffer, and the number of bytes to send/received |
- See also
| void bcm2835_spi_writenb |
char * |
buf, |
uint32_t |
len |
Transfers any number of bytes to the currently selected SPI slave. Asserts the currently selected CS pins (as previously set by bcm2835_spi_chipSelect) during the transfer.
- Parameters
| [in] | buf | Buffer of bytes to send. |
| [in] | len | Number of bytes in the tbuf buffer, and the number of bytes to send |
